TwinTurbo.NET: Nissan 300ZX forum - when he said "very light grit - no more than 600"
Subject when he said "very light grit - no more than 600"
Posted by ScubaSteve on May 26, 2004 at 9:13 AM
  This message has been viewed 24 times.
In Reply To particle size increases as grit number decreases posted by fourZero on May 25, 2004 at 04:55 PM
Message this sounds incorrect. The lighter/less rough the sanding, the higher the grit. The harder/rougher/courser the sanding, the lower the grit.
When painting over a painted surface, you usually use very light sanding, just enough to dull it / slightly scuff the paint, to give the new paint something to stick to. If you use too course of a grit, all the scratches are too deep and you can see it in the new paint. Auto paint base coat is so thin its like practically water. But this is bedliner coating. Are you guys saying it needs a really rough surface for it to stick to? thanks,
random sig pic of the day:
TAMPA BAY LIGHTNING - TIME TO STRIKE!
--.scubasteve.--
